P1225/M1225 Looking for programming cable
DatedGore
Indiana
Hello I was looking around and couldnt seem to find any programming cable for the p1225, the only ones I could find were no longer being sold or discontinued. Just wondering if anyone could shoot me a link to one.
jeepsandradios
East of the Mississippi
The P1225 did not use a cable. It programmed thru the battery with the adapter shown above. I was able to make a few when I worked for the shop out of old chargers but not sure where the diagram went.
buddrousa
You are not going to find a $20 cable for a 1225 they worked with a Rib Box and DOS or Windows 95 SLOW PC you had to run software to slow pc,s down or it would not work. Do You have a 100 Meg Prosser pc?
DatedGore
Indiana
I have the software, I have two computers that came originally with windows XP but until I get home I can not tell you the processor speed
DatedGore
Indiana
Adding on I forgot to say I also have a older laptop, It's a Dell Inspiron 1200 and I am not sure but 1.3 mhz Celeron CPU if I recall but I would have to check, how slow exactly does it have to be?
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
You are definitely in the realm of radio archaeology. If I had to try to source an old enough laptop to try to work with a 1225, I'd just say no and get on with my life. I'm kind of shocked that you can get replacement batteries for them.
Windows 95 has a minimum CPU requirement of a 386DX. It'll run on up to a Pentium 4 and with the appropriate patch can run on machines with a clock speed beyond 2.1 GHz.
But that doesn't say that the RSS will work correctly.
Try what you have, see if you can read the radio with it. If it reads with no data errors, it's probably safe to use to program the radio.
DatedGore
Indiana
Alrighty I am currently getting a new hard drive for that laptop so I will probably put windows 95 or xp on it. I really love the old Motorola radios if I'm being honest and it helps that you can still get the batteries and what not for them. Motorola's new radios are good and all but I just want to have a little bit of the past. Thank you and I will keep you updated
jeepsandradios
So besides the programming stand above you need a RIB box. The DB 25 on the programming cable plugs into the RIB then to the PC 9 Pin Serial Port. Dont plan on a USB adapter as it most likely wont work.
DatedGore
Indiana
I plan on buying the RIB box here soon, or hopefully find it at a upcoming ham fest. Yea I know to stay away from USBs but my laptop and desktop computer have a serial port
DatedGore
Indiana
Version 4.0 of the CPS runs just fine on an XP computer. MOL still has it under Discontinued Software plus it’s easily found on the net. And it’s a Windows program, not a DOS executable.
Thank you, I had already put a version on my Windows XP desktop
Twlighting
Los Angeles, CA
For what it's worth, I did have success programming P1225s using a cable similar to this which incorporates the RIB circuity and provides a RS232 programming interface.
It was done on a 2008 Macbook running Parallels 11 w/ WinXP and a USB>Serial converter. Not a recommended setup by any stretch, but confirming that WinXP on a computer with a real serial port should be able to get it done.
DatedGore
Indiana
I had purchased that cable a few days ago and yes It is a Windows application, I have it all setup just waiting for the programming cable! I'll keep you guys updated
