looking for signal ID
cg
Connecticut
I have recorded this from a new trunking system in CT licensed to Northeast Utilities. This is from 935.4375 (at the Hoskins Rd site in Bloomfield CT for the local folks).
I don't know if this is a new type of trunked system or perhaps a placeholder signal. I get no results running Trunker on it (normal or inverted). Slicer program shows some good sharp spikes and is probably better than many TRS that I can hear.
Here are some samples
cg
Connecticut
That makes sense as it is replacing a GE SCAT system but ETrunker shows nothing. Is the provoice data channel different from regular EDACS? or perhaps the narrow EDACS? It doesn't sound like the normal EDACS systems.
chris
click23
Athens, Tennessee
I have only listened to an edacs system a few times and really never paied attention to the CC. You might want to try t4win for that system. Its says it is edac48, I am new to all this so I have no idea what that means. All you will have to do is click the sampling box and select you imput with t4win and you will be up and running.
Robert
cg
Connecticut
Thanks for the hint about the 4800 baud.
I had forgotten about the 4800 baud EDACS systems. I ran ETRNK48 on the signal and now I get a 98.9 accuracy on it but it lists it as sys id 1234 and as "unknown NetWkd"
Perhaps it is too new but I think I should be getting a SYSID.
I will have to go the route of T4Win
thanks again
chris
