UHF ANTENNA OFF MAXON SP130 , WANT TO INSTALL ANTENNA ON SCANNER , NEED A SMA CONNECTION THAT WILL ALLOW THIS ANTENNA SCREW INTO ,, SMA TO BNC ADAPTER , MALE / FEMALE BNC , DOES NOT MATTER , THANKS
4Pcs RF Connector adapter SMA female to Jack Female Straight adapter Connector. Family: Coaxial, RF - Adapters -SMA. Convert From (Adapter End): SMA Jack, female Pin. Convert To (Adapter End): SMA Jack, female Pin.
Some posts, but I think they were looking to put a BNC antenna on a radio with a MX female connector. There seem to be lots of MX male to BNC adapters available, but not in the reverse.
Hello, I'm in need of some Motorola expertise.... Reading through some forums, people swear that mx to bnc adapters for Motorola ht's work. I have a couple of the Waris and Mototrbo lines. Ht750/1250's and xpr 3300/6350. Looking at the antenna jacks on these radios, I feel that a bnc adapter...
Hello all, I am new to the forum and new to radio tech. I have a radio that uses the MX connector on the antenna which is the same size/tread pattern as SMA female but has no center pin hole. I am trying to relocate my antenna on my Motorola 2 way, the kit I have is all SMA connectors. With this...
For use with MX Motorola Maxon Midland Tekk ICOM Radio GP68 HLN8262A. DOES NOT WORK WITH ICOM IC-F4161. SMA Male to BNC Male Radio Antenna Adapter. Allows the use of antenna with BNC connection.
www.ebay.com
This looks interesting, but I can't see the other side of the adapter.
