Ok.. then do this:
~ is a tilde, not a dash
make sure you do line 2 below BEFORE you do anything else below it
Code:
cd ~
umount /floppy2
rm -rf /mnt/floppy
rm -rf /mnt/floppy2
mkdir /mnt/floppy
mount /dev/fd0 /mnt/floppy
cd /mnt/floppy
ls
cd ~ (just makes sure you are not in the directory you are trying to unmount nad delete)
umount /floppy2 - will unmount your floppy so that you could remove the disk if you wanted [but you dont have to]
rm -rf /mnt/floppy (will remove the "file" named "floppy" in /mnt)
rm -rf /mnt/floppy2 (will remove the directory named /mnt/floppy2 since you dont want to use it)
mkdir /mnt/floppy (will create the directory /mnt/floppy so the drive can be mounted to it)
mount /dev/fd0 /mnt/floppy (will associate the floppy drive contents iwth the directory /mnt/floppy)
cd /mnt/floppy (change directory to the directory with the floppy drive contents)
ls (just to verify you see the contents of your floppy)
The " rm -rf " commands are instantly destructive - no prompting before removal, it'll just remove them. So always be careful when doing rm -rf
Mike
