Looking for someone to program 500m...
acepilot340
Joliet, Illinois
This is the system I am interested in getting programed on my 500m. Will County Public Safety Trunking System, Simulcast, Illinois - Scanner Frequencies
AFS Alpha Tag
04-021 East Patrol
04-022 West Patrol
04-023 East C2C
04-024 West C2C
04-097 LWPD
05-041 East Com
04-081 Rockdale C2C
05-042 Beecher C2C
05-043 Monee C2C
05-044 Peotone C2C
04-082 Manhattan C2C
04-083 Elwood C2C
04-121 FrstPrsv PD Ch1
04-122 FrstPrsv PD Ch2
11-031 NL ESDA
Thats all the talkgroups I'm interested in monitoring.
As far as what I would like on the radio.....
-RX ONLY
-Disabled Emergency button (unless it doesn't cause an issue with the radio)
-A 2 second hold time
Also I do not have the proper power connector for the radio, I cut it off and used a model train transformer to power it up and I plan on wiring it up to my truck later so I didn't feel the need to keep the 3 prong connector on it.
As far as the antenna connection, I have a NMO coax, but do not know what kind of connector the back of this radio uses, does anyone know what the proper antenna connector for the back of the radio?
I do need to know how to hold on a certain talkgroup, like with a scanner you can hold the scan and stay on the one talkgroup you want. Is that possible with this radio?
As far as what you charge, let me know and I'll get back to you, just so you know I will cover all shipping charges...
Thanks,
Marc
Thayne
Just a few tips;
The radio cannot use AFS for talkgroups, has to be DEC
The antenna conector is a TNC
The scan button toggles, so you can make it stay on any group programmed
Emergency button won't work if it is not programmed to transmit.
Just be sure the power polarity is right or you could let the smoke out
acepilot340
Joliet, Illinois
Just a few tips;
Thank You for the info.
