Looking for splitters
n5ypj
Hi
I have 2 scanners and 4 SDR-RTL that I would like to connect to a VHF (150 MHZ) ground plane antenna just a little above the roof line for local reception. As a ham I've switched antennas and transceivers but for this I'd like to combine or have all the receivers connected simultaneously.
I'd appreciate any recommendations of splitters or couplers and any general advice in the best way to do so.
Thanks for your time. Have a super weekend.
Richard
buddrousa
You will see people tell you that BNC T's will work and TV SPLITTERS will work along with TV AMPS.
It may work and you may get noise from scanner to scanner. What listed above is the only option I have tried that works 100% GREAT a little pricey but you get what you pay for. I am running 12 scanner receivers on my desk right now no signal loss only using a preamp set to a low gain to amp the 1st split.
