BTW,.. Anyone that monitors Keesler AFB, if you get the callsign of the Hurrican Spotter's Aircraft, and the freq's its using, post it would ya??? Thanks in advance.
Aircraft call signs are "TEAL-nn" (where nn is a 2-digit number), "NOAA-42", "NOAA-43 and "NOAA-49"
Hurricane reconnaissance aircraft now primarily use milsat to relay recon data to the National Hurricane Center.
US Global High Frequency System (GHFS) frequencies
03407.0 USB National Hurricane Center air-gnd "ALPHA"
04724.0 USB Hurricane hunter acft - GHFS
05211.0 USB SHARES - FEMA National Emergency Coord Net (night pri)
05562.0 USB National Hurricane Center air-gnd "BRAVO"
05610.0 USB National Hurricane Center air-gnd "CHARLIE"
06673.0 USB National Hurricane Center air-gnd "DELTA"
06712.0 USB USAF GHFS SAR
06739.0 USB Hurricane hunter acft - GHFS guarded by Ascension
07507.0 USB USN/USCG hurricane net (pri)
07508.5 USB FAA Caribbean hurricane net
08876.0 USB National Hurricane Center air-gnd "ECHO"
08968.0 USB Hurricane hunter acft - GHFS
08992.0 USB Hurricane hunter acft - GHFS guarded by Ascension
09380.0 USB USN/USCG hurricane net (sec)
10015.0 USB National Hurricane Center air-gnd "FOXTROT"
10493.0 USB SHARES - FEMA National Emergency Coordination Net (day pri)
11175.0 USB Hurricane hunter acft - GHFS guarded by Ascension
13200.0 USB Hurricane hunter acft - GHFS
13267.0 USB National Hurricane Center air-gnd "GOLF"
15016.0 USB Hurricane hunter acft - GHFS guarded by Ascension
17901.0 USB National Hurricane Center air-gnd "HOTEL"
17976.0 USB Hurricane hunter acft - GHFS
21937.0 USB National Hurricane Center air-gnd "INDIA"
Didn't most of the primary communications from the Hurricane Hunters move to a satellite system a few years back? However, I read they still use HF as a backup, should the new system fail.
