Loop size vs gain - question
dave-h
Is there a general rule for determining loop gain versus the size? I have an untuned 3 metre diameter octagonal shape moebius loop used for medium wave DX and I'd like to estimate the approximate gain I could expect if I increased the area.
The approximate area of the 3m loop is 7 sq. metres and a new triangular shape loop I'm building will be 47 sq. metres. I thought I saw references on the internet to somewhere between 12 and 15 dB every time you double the area of a loop but I cannot locate that information again after extensive searching. This no doubt referred to a tuned loop so untuned loops may well be different.
If this is true then could I expect something in the region of 30 to 40 dB increase in signal? Personally it sounds a little on the high side but I thought I'd ask here to see if anybody has experience with this.
Many thanks.
Dave
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Dave this reflector on the popular groups.io listserver seems a very busy place, and maybe somewhere you can get some answers
This ain't Yahoo. I belong to several groups on this server and very little scam junk gets through. It depends much on the moderator, of course
Mike
devicelab
Whacker Extraordinaire
Nowhere in WA
Is there a general rule for determining loop gain versus the size? I have an untuned 3 metre diameter octagonal shape moebius loop used for medium wave DX and I'd like to estimate the approximate gain I could expect if I increased the area. The approximate area of the 3m loop is 7 sq. metres and a new triangular shape loop I'm building will be 47 sq. metres. I thought I saw references on the internet to somewhere between 12 and 15 dB every time you double the area of a loop...
That seems pretty large but I guess it depends on the specific frequency range you're working. I have a fairly large delta-loop-like antenna that is about 200ft of 14ga wire into the Wellbrook ALA-100LN.
I tried the recommended loop size of 10-15m a few years ago. The difference between the two was quite significant; however, I wasn't looking at MW frequencies. On general shortwave frequencies (3.5-20Mhz), it was pretty incredible.
Shortly after, the noise appeared... and conquered all. :mad:
