Loose display at BR330T ??
AOR-AR
Hi,
i have noticed that the little plastic display are loose at my BRAND NEW BR330T. If i push down the display "very careful" then i can see how it going down in to the plastic body. I think this problem exist because the manufacture have use to little of glue at the plastic displays edge and to the body. There are very poor contact between the display and plastic body.
And a lot of dust leaked in under the display. Anyone else who have this same problem ?
Try to push down your own plastic display..push at the two lower corner and see whats happen?? (Please let me know later)
I think it's exately the same problem with the big brother 396T.
Regards: AOR-AR.
DaveIN
Founders Curmudgen
West Michigan
Hmmm... Not seen that problem with any of my Uniden scanners. You sure you didn't forget to remove the plastic protective sheet after you took it out of the box?
AOR-AR
Hi Dave
Yes i'm sure..i have not forget to remove the protective sheet. The problem is that i live in Sweden, and it seem that no one more than me have this US model BR330T.
I have no one to ask over here in Sweden.
