Loretto Fire
exkalibur
York, Ontario
Hey guys... can anyone give me an idea what Loretto Fire is using? I had them programmed as Adjala-Tos on 158.something.
But, I haven't heard anything for a little while. I see they're using new CP200 radios now - did they change frequencies as well?
Thanks!
mciupa
DB Administrator
Moderator
Looking at Mike's Simcoe County WIKI entry , STN #2 (Loretto) is in Adjala using 158.235 for dispatch and 167.765 (754 DPL) for fireground.
That info is current as of Dec. 27, 2007.
imcleish
Durham Region and Parry Sound, Ontario
and the Answer I have received from a Crew Chief within the Loretto Department of Volunteer Fire Fighters is:
"We are still on 158.235, the tones are still the same, the radios are now Narrow band Compliant, and our area of use was defined"
So re-program your scanner to NFM mode.
I was also told the Firefighters have become less than pleased with the changes in signal strength throughout their areas of use, so hope for some changes to their repeater system which will allow for easier monitoring.
Request for update submitted
mikewazowski
Staff member
Central Ontario
imcleish said:
"and our area of use was defined"
Actually the changes will make it harder to monitor since they are trying to keep their signal within their operating area.
Clearview and Oro-Medonte have also recently undergone simulcast improvements which meant more coverage within their areas but less coverage outside.
