Saving your profile only saves one small file to disk that contains your profile settings - and your profile settings are things like your volume and squelch, startup screen text, which favorites lists to use, and which service tags to use.
It's true that the avoid settings are stored in your profile folder, but if your avoid settings are being wiped out, something's not working right. I still don't know if these avoids are in your favorites or the main database.
If it's the main database:
I forget where the initial installation stores your data, because I have moved mine to a different location. But you can figure out where your data is by going Tools>Options in the main Sentinel window.
Go to that folder in Windows Explorer, then in that folder, choose Profile, then select the profile in question, then HPDB. Inside that folder you should see several .avd files. Do you?
If the "missing" avoids are in your favorites lists, the state of those avoids are stored in the favorites lists themselves. Your favorites lists are stored in a different location - in the folder mentioned above where you chose Profile, choose instead FavoriteLists, and you should see several .hpd files. These are your favorite lists.
Lastly, here's the step-by-step process for updating your scanner. This will ensure that everything that's in your scanner when you start this process should be there when you finish, with the exception of the the updated main database. (Forgive me if this is stuff you already know - I figure it can't hurt to share it.)
First thing to know: You can update the database in Sentinel at any time you wish, irrespective of whether you have the scanner connected or not. The Sentinel database is ready to be downloaded from the Uniden server every Monday morning at about 10AM MDT.
So let's start with updating the database. Start Sentinel, and click on either the second-last icon on the toolbar (a picture of a globe with a computer screen in front of it), or click on "Update Master HPDB" inside the "Update" menu item. You'll get a dialog box that comes up showing the process. Eventually you'll either get an update complete message, or a 'this database is the current version' message. Either way, once that's done, in the lower left corner of the program screen, you'll see the date of the most recent database, which will hopefully be the most recent Sunday (mine currently says "Database Version: 03-15-2015").
Anyway, the process of reading and updating the scanner is this:
- Plug in the scanner, wait for it to be recognized.
- In Sentinel, select Scanner>Read From Scanner.
- Choose your scanner on the dialog box which shows up next.
- Run through the prompts, and as I said in previous messages, if you're prompted, choose "Copy & Replace on Computer".
- Once it's done copying, check in the database browser to confirm your avoids are present.
- In Sentinel, select Scanner>Write To Scanner.
- There's an option you can try here, and in your case, it's probably wise to use it. Select BOTH of the boxes in the dialog, which state "Erase Favorites Lists on Scanner" and "Force Write Full Database". The one about the full database is not normally used, but can help repair problems if your database somehow gets corrupted. The one about the favorites lists I use quite a bit more often. It seems like from time to time, your scanner can get multiple copies of your FLs on the SD card, and confuse itself, with an older copy of a favorite being used instead of a newer updated one. Using this check box will wipe out all the data in the FavoriteLists folder I mentioned above, and put new data in from the computer.
- When this is done, a pop-up will say that the update is complete. Don't forget to use the Safely Remove Hardware function in Windows before you pull the USB cord out.
At that stage, your scanner should be updated, and you should still have your avoids. If you don't have your avoids, my next step would be to uninstall Sentinel and reinstall it.
