Loss of signal when using one antenna with two scanners
n1chu
Farmington, Connecticut
Two BCD996P2 scanners fed by one antenna using a BNC “T” as the splitter. The antenna uses a “N” connector and the LMR400 coax has “N” connectors on both ends. An adapter was added (N to BNC) to feed the “T” connector and two runs of LMR400 feed the scanners.
While receiving a trunked P25 system one scanner hears this system but the other does not… it did when it was first added but now it doesn’t. Only one of the scanners if adversely affected-it’s always the same scanner. Both scanners are programmed identical-cloned. Any ideas why this happened?
It should be noted that while both scanners are programmed identically (cloned), and a simple extension speaker should be all that’s needed to hear the same in two different locations, it was decided a second scanner should be used in order to allow for lockouts for the two respective rooms being served. One room is a meeting room and the other is the dispatch center in a firehouse. It gives either location the ability to “Avoid” certain agencies, lower volumes, etc.
kc2asb
NYC Area
I tried one of those a few years back. Enough issues like yours made me change course to get a stridesburg 4 port. Problem solved.
Same here. I found that the scanners can interfere with each other as well. The distribution amp is the best solution.
Wish I had known about these 15+ years ago else I would not have installed multiple antennas!:ROFLMAO:
bearcatrp
Land of 10,000 taxes
Thought about multiple antennas but decided a discone that covers up to 3Ghz covers my needs. Can always get a pre amp if needed but so far not needed.
W9WSS
Retired LEO
Westmont, DuPage County, IL USA
T-connectors will cause issues between both scanners. Obtain a Stridsberg or equal quality pre-amplified splitter. Your problems will be solved. I own three Stridsberg's for various scanner configurations in two areas of my QTH.
KevinC
32D2T/957.282
I'm everywhere Focker!
Like everyone else said, a "tee" isn't the best choice, but since it used to work and now it doesn't something changed. I'd (obviously) suspect the cable from the tee to the non-working unit.
wtp
Port Charlotte FL
anyone touch the squelch setting, it should be on 2.
also if some of the stuff you listen to does not need an outside antenna, don't use it.
n1chu
Thanks for your inputs. The question was posted by myself on behalf of a friend who, after doing his own research became confused with the Stridesburg’s, Combiners/Splitters, in-line amps, with each having their own drawbacks such as the ability to isolate, db loss on numerous bands, not to mention the prices.
kc2asb
NYC Area
When Radio Shack was blowing out the #20-176 groundplane antennas, I bought several and installed them in one of the eaves in the attic and ran the feedlines down two floors. Out of sight and out of mind, and they work quite well.
I'm in RF Alley/NYC area, line of sight to Manhattan 5 miles to the northeast. Outdoor antennas tend to cause overload/desense issues.
KevinC
32D2T/957.282
I still vote for something changed and I'd look at the cabling from the tee to the non-working unit seeing how it used to work. But I've only been troubleshooting things for 50 something years, so I could be wrong.
kc2asb
NYC Area
50 years? Wow. I didn't even think you were 50 years old. :) I agree with you here. If it was working before, check for problem components in the installation.
