As said, first be sure the noise is not in your home. The worst noise sources are those nearest to you. You'd be amazed at the stuff that can be noisy, TV sets, computers, monitors, battery chargers, game consoles, lights, dimmers, furnace controllers, ethernet routers and switches (these are notorious) washing machines, the power supply to almost anything these days, and on and on. A portable AM radio is your friend. Turn off all your power. Tune the radio to a vacant frequency. A multi-band shortwave is best for this so you can stay away from the strong broadcast stations. Walk around the area, check neighbor's house, street lights, etc. If it's indeed noisy at power lines you can call the power company. Are these indeed high-tension lines? If so there's not much that can be done. They radiate by default due to the high voltage. If this is a neighborhood feed however they will listen to complaints. Power line *leaks* are bad and they want them fixed. If the noise is gone with your power off you know it's local. Begin turning things on and listening.
I've heard computer sound cards and ethernet switches (and the wires) that radiate wideband hash for blocks.
