LoTW for Linux question
geraldw3210
SE Penna.
Hello everyone. im trying too get my certificate recognized in Lotw. i run Lubuntu 17.10 tqsl v2.3 i got the certificate via email but it will not be accepted by lotw.
anyone had success with this??
popnokick
Northeast PA
Did you compile and build a linux version of TQSL? You need to load the cert into the TQSL app. If so, is that where you are having a problem (loading cert into TQSL)?
geraldw3210
SE Penna.
Hello there
Thank you i installed TQSL thru a repository via synaptic, Now i did do the update and install the cert, then it took my certificate and is working well,
Thank you again i appreciate the help 73 KC3JET
