Louisiana Wireless Information Network (LWIN) Discussion
fireman1417
Louisiana
I'll post updates when it's back up, looking at several more weeks, FD radios are being reprogrammed over the next couple weeks. From what I'm being told, expect encryption on SO dispatch, maybe not immediately but it should be expected. Currently Ascension and St. John SO are. FD won't have any encryption.
AC0RV
Park Hills, MO
Radio UIDs
Some time back I posted a list of talk groups and radio UIDs to be id'd . I still help on iding them.
Also Does anyone have a list of radio Ids for the Washington Parish area. I would like to check my list against yours. Please send them in form of a Spreadsheet CSV File to fullerdavid63601@gmail.com
Thanks in advance.
shew
PIERRE PART, LA.
Wirelessly posted (I phone: Mozilla/5.0 (iPhone; CPU iPhone OS 6_1_3 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10B329 Safari/8536.25)
On tg 32069 on the lwin system i heard law enforcement traffc...one call i heard was a vehicle stopped at a light on main and airline....5 minutes later as i was passing there going to work there it was....st. John s.o. On the scene
loumaag
Silent Key - Aug 2014
Katy, TX
Seems like a reasonable catch. the lower 32000s seem to be PS in the river parishes area with St James being toward the bottom and St Charles being at the lower 32100s. Of course I suspect that dispatch will end up being encrypted once everyone gets on board.
shew
PIERRE PART, LA.
St charles has their ncic tg encrypted since day 1
St Charles FD
St Charles FD announced today that they will switch over too the VHF 700mhz LWIN system Monday April 8th at 9am!
shew
PIERRE PART, LA.
Thanks squeeker...i will have my scanner tuned in for my ride home from the power plant in montz
shew
PIERRE PART, LA.
what happened to st. john sheriff office....they was on the lwin system....Monday and Tuesday ......haven't heard them at all Wednesday or today......
fireman1417
Louisiana
They had a problem with their system going recently, they may have been on LWIN temporarily. Sometimes I hear them when they are running traffic, I think they use it to get off of their dispatch channel. Or they may have switched over for part of the upgrade process. Their system is one that is going to be tied into Ascension with St. James.
fireman1417
Louisiana
Been hearing St. Charles doing some testing for their Fire channels on LWIN. Sounds like they're making the switch. They were testing paging tones and confirming whether both the LWIN dispatch and the VHF pagers were recieving.
rhattala
Hammond, Louisianan
Hey I hope im in the right spot,I just got a Uniden 396xt and i have been using Freescan with my RR subscript and trying to program this is a headache. Im in the hammond area and trying to scan Tangi(LWIN), Livingston (conv), STTammany (LWIN and EDACC), NOPD (LWIN), EBRSO AND BRPD (LWIN) and TROOP L and A. and cant seem to set the groups up right to select. Do i need every LWIN site in the system to scan?
IF someone has a freescan file set up similar I WOULD GREATLY APPRECIATE IT! if not if someone could help me out i would be grateful! THANKS
INDY72
Indianapolis, IN
No, you don't need EVERY site on the LWIN. You need the sites in the areas you are trying to monitor. You may want to set up a "Home" and "Travel" arrangement. Remember, you most likely are not going to hear NOFD, NOPD, NOEMS, BRPD, EBRSO on the site at Hammond unless a unit with those talkgroups programmed in thier radios affiliates with that site. St. Tam is mostly ProVoice digital, and can't be monitored on any scanner. (You must use DSD and a patch cable from the scanner to PC to hear that.) If your travelling in the areas of EBRP, OP/JP, you want to set up the sites youll be nearest.
trido
Southern In
LWIN and BCD996T and freescan
I was programming a BCD996T NOT XT with freescan for LWIN and got error on i think all sites scanner wants BAND PLAN?
Well I thought no plan needed on a P25 system
I programmed it for moto typeII/P25.The P25 setting says for XT models.
Has anyone had any LWIN issues and the 996T scanner.
Hate to ship it back from IND to LA and it not working.
Thanks for any help
safetyobc
South Arkansas
Limits on the 996T are:
Sites: 1000 maximum, 256 maximum per system
Groups per system: 20 maximum
Talkgroups per trunked system: 250 maximum
I hit the talk group limits on my 996T. Really wish it was upwards of 750 or 1000 limit on talk groups.
trido
Southern In
Thanks I am way under these limits just have no idea still says for every single LWIN site no band plan?
Scanners firmware is upto date
Maybe I try ONE sigle site and nothing else for a test
trido
Southern In
Maybe this be a clue the freescan error says FTO upload error?
Anyone seen a FTO error?
then below is where is shows all LWIN sistes need a band Plan.
I try a master scanner rest
thanks
