Louisiana Wireless Information Network (LWIN) Discussion
shew
PIERRE PART, LA.
It's live this morning. It appears they may be starting to use existing tower sites. I noticed the Baldwin site was not put on a new tower either, It was put on an existing tower with other antenna's on it (Cell, Microwave, etc...) Also recently I noticed the tower that was at the troop c station in Gray with 700 antennas is gone and now being used on another tower with Cell antennas on it (shared). I guess the state figured it is cheaper to go that route. If that is the case with the Gray tower that may explain why for the last several months I have a hard time receiving the Gray tower since it has moved, even though it has not moved very far, it has been harder to receive unless the weather permits. Maybe its not as high as the previous one. I used to pick it up 24/7
it might be on the cell tower right before the la 182/la 20 split...my opinion...or the one by max welders
teebee
Lake Charles, LA
I need some advice. I am not sure if I am having scanner issues or if the sites in question have had some changes. Up till about 8-10 months ago I was able to receive Jeanerette, Gray and Bayou Towers 24/7. Now I cannot receive them at all. Occasionally/rarely I can receive them depending on certain weather conditions. Most of the time when I hold the CC there may be one to two bars. However when I turn the squelch down to zero I can hear what appears to be some type of interference. There are times when I am locked on a CC there is no signal bars for a moment then suddenly its like someone is keying up and a bar or two displays. Bottom line its like there is another site or channel that is overriding these site Control Channels. Now here is the funniest part, I have programed all of each sites frequencies listed into conventional mode and scanned them and can hear traffic on everyone of them from those three site. Just cannot get the cc data. On a side note I can always receive Paincourville, Theriot and Vacherie 24/7 with no problem and yet they are much further away from me than the three I am having issues with. There a few others I can pick up even further most of the time. Any suggestions please help. Not sure why all three would do this at the same time. Maybe a setting in my programming
INDY72
Indianapolis, IN
Please don't say its on an HP-1.... If so, this now adds to the growing list of issues these are now seeming to be having on P25 systems...
teebee
Lake Charles, LA
No reply regarding my issue not receiving CC on certain sites. Still confuses me as to why I can receive the actual channels/freqs in conventional mode and here traffic. By not receiving the CC and only getting interference and static I am not able monitor each site in trunk mode. Actually early this morning I was able to get the CC on each site till around 10 am, then lost them. I was able to listen to the conventional freqs for each site through out the day. Of course trying to listen to them that way you really can't tell who is who without id's. This whole deal is so strange.
derekdauzat
Marksville, Louisiana
help
im live in marksville la, avoyelles , i would like to get in to this and have been doing some research, but im hoping that a bct15x will give me something to listen in on, in my area, i was hoping that i would not need digital, hopefully this can pick up some police, and other agency's here, please help me out
shew
PIERRE PART, LA.
this is a digital system....for avoyelles
Avoyelles Parish (05) - Public Safety Talkgroups
45002 afca D 5-MARKSVL PD Marksville Police Dispatch Law Dispatch
45000 afc8 D 5-LAW DISP Law Enforcement Dispatch Law Dispatch
45001 afc9 D 5-FIRE DISP Fire/Rescue Central Dispatch Fire Dispatch
45003 afcb D 5-BUNKIE PD Bunkie Police Dispatch Law Dispatch
45004 afcc D 5-LAW PTRL1 Law Enforcement Patrol 1 Law Tac
45026 afe2 D 5-TBTPD DISP Tunica-Biloxi Tribal Police Dispatch Law Dispatch
45042 aff2 D 5-FIRE FG1 Fire Tactical 1 Fire-Tac
45043 aff3 D 5-FIRE FG2 Fire Tactical 2 Fire-Tac
154.66500 is the parish fire dispatch
derekdauzat
thanks, i did not get the bct15x...
i did come across a good deal for a bcd996t and it should be delivered to my house Tuesday, so hopefully this will do some good, also i live in Fifth Ward la its about 8miles outside of Marksville, and their are a few hills and wooded area in between, will i need a better antanna or will i be ok with stock?
Natchitoches
Unlisted Sites
Both Hagewood and Many show connected with site 4-11 on 769.21875 (c)
Many also shows connection with 4-24 on 770.44375 (c)
Neither are listed in database and FCC search is fruitless with way LWIN is licensed.
No need in me trying area 4 sites from where I am unless LWIN is back to numbering out of normal areas again.
Maybe someone will find use for these where they are located so at least I have shared info.
Anyone have ideas???
INDY72
Indianapolis, IN
Submit new sites and tg's through the submission buttons. Once they are in Que, I or other admins can add the data. TY
Natchitoches
I understand the submission process but do not have enough info on those sites to make a usable submission. I put that post in so maybe someone else would be able to complete needed info.
KE5TLF
MS Gulf Coast
Looks to me like Hornbeck and Leesville have been reassigned to zone controller 4 now. Fairly easy to deduce with just that information, as long as the info for those two sites are accurate in the DB.
(EDIT: I submitted the changes)
LWIN Rapides Parish
Would be great if somebody in Alexandria area would analyze the Rapides LWIN towers. Lots of changes going on there, unfortunately, lots of encryption too.
