low audio from dc thru tk790
ashfire
st. helena ca
I have installed a new kenwood tk790 and teh audio is low when transmitting from the david/clark headset.
I understand it can be as simple as checking a box in the programming section when computer is hooked up for programming.
Does this sound accurate to anyone?
Also why in hell are they not making a patch connector for the kenwood to dc headsets?
Why are we still having to strip wire to a bus block?
I will be making a patch connector for all to use check back when available , soon.
This is because I want teh fire service to be easier less time worried about radios and more time running calls doing what we are supposed to do,
ramal121
Sonoma, CA
A question for David Clark I guess.
Are you connecting the radio cable for the headsets to the control head or the 25 pin accessory connector at the back of the radio? The 25 pin connector requires a jumper to be moved inside the radio (assuming this is a remote mount config).
