what would be a good Ant. for low band eg. 33.980 mhz?
firefgtr Member Premium Subscriber Joined Dec 7, 2004 Messages 526 Location Welland, Ontario Canada Jul 1, 2006 #1 what would be a good Ant. for low band eg. 33.980 mhz?
I intrepid97 Member Joined Jun 23, 2006 Messages 178 Jul 1, 2006 #2 I would look for a used commercial low band antenna or someting like this,look at the antenna at the bottom of the page. http://www.mpaudio1.com/CBANTTENAS.html
I intrepid97 Member Joined Jun 23, 2006 Messages 178 Jul 1, 2006 #3 You could also get a 102-108 inch CB whip antenna and trim it down to match the 33Mhz range and it will perform quite well for you. I just looked and RS carries the antenna. http://www.radioshack.com/product/i...kw=cb+antenna&kw=cb+antenna&parentPage=search Last edited: Jul 1, 2006
firefgtr Member Premium Subscriber Joined Dec 7, 2004 Messages 526 Location Welland, Ontario Canada Jul 1, 2006 #4 thanks.............but i was needing it to be for a portable scanner, sorry i should have mentioned that, me bad
I intrepid97 Member Joined Jun 23, 2006 Messages 178 Jul 1, 2006 #5 Hera ya go... http://www.rfwiz.com/Comtelco/ComtelcoPortableAntennas1.htm http://www.comtelcoantennas.com/PDF Datasheets/PEXL.pdf http://www.comtelcoantennas.com/PDF Datasheets/PEXW.pdf
firefgtr Member Premium Subscriber Joined Dec 7, 2004 Messages 526 Location Welland, Ontario Canada Jul 1, 2006 #6 there we go..................thanks
I intrepid97 Member Joined Jun 23, 2006 Messages 178 Jul 1, 2006 #7 Not a problem,Hope you find one that will suffice for what you need it to do.
