Low Band Pipe Mount That Takes 4 whips, one vertical and 3 ground radials?
BirkenVogt
BirkenVogt
Does anybody remember these? Back when low band was popular we used to use them for base stations but not I can't find any or even the part number. They accepted standard CB style whips, 4 of them as the title says and an SO-239 connector and mounted on top of a piece of 1-1/4" or 1-1/2" pipe. The cable ran up the inside of the pipe. A manufacturer, part number, or anything would be helpful
Birken
freddaniel
Newport Beach, CA
It was 4 whips down, and 1 whip up. It is called a ground plane and the whips are 3/8-24 thread. Good luck finding just the hub assembly. look at CB antenna manufacturers and maybe cut it down to the frequency required.
Real low-band antennas at Tessco or Talley are very expensive.
freddaniel
Newport Beach, CA
The ASP model is no longer available. Look at SauderElectronics.com for their mounts. Their 3/8-25 to SO-239 mount is what you need. Just add some additional hardware to support the ground plane, you have what you need. They also sell the 3/8-24 ferrule so you can buy stainless rods at a local metal supplier like SpeedyMetals.com
Also look at AntennaPartsOutlet.com for additional hardware for mounting.
