HI All,
Hopefully I have posted this in the correct chat
I have a discone antenna (25-2000Ghz) that will be going up soon with a 28ft length of LMR400 cable to the shack. I also have a low noise amp but wondering if I can get away with it on the receiver end due to the use of LMR400 cable (as will be an easier install) or does it have to go on the Ariel end?
Also not sure if the LMR400 N connectors are different to normal N ones? as the N connector on the Ariel seems to not fit the internal ring as per the pic?
Regards
Christopher
Regards
Christopher
