rinkerk
- Joined
- May 10, 2005
- Messages
- 41
- Reaction score
- 0
Hey neighbors,
I live in a fairly remote area of Rio Rancho.
I've noticed that the old 50+ longwire is getting alot of QRM, static etc.
I had planned on setting up another 100+ longwire about 40' at the highest point ( running almost perfectly north) and comming down slightly at about 30' AGL at the end point.
I plan on getting the VHF/UHF muli-dipole ( "Scantenna" ) up to about 40' AGL using a vent mounted mast on the roof. I think the VHF+ will work great, considering most I want to hear is pretty much line of sight, and my QTH elevation is great.
My question is: Now that the power lines and encroaching houses they are building in this area are creating more and more QRM, what do you recomend ( besides moving to another location:0 ) ? I'd kinda like to build a low impedance HF longwire fed by R8 or R6 end fed at the mast on the roof, then slope down to a PVC mast about 20' AGL at the distal end.
I'm kinda thinking that just a longer wire will improve, but I think the Sig/noise ratio will increase at this lenght.
Anyone have some good ideas on a end fed coax slighly sloping longwire?
I'm thinking that I'll have to use an antenna tuner to match impedance to the SAT 800 reciever. Any other ideas? Thanks for helping...........
Regards,
Kevin
Regards,
Kevin
