Not sure where you found that, but it's a photo of one type of antenna with a description for a completely separate antenna. I'd not purchase anything from a vendor that wouldn't know the difference between those two antennas.
The Larsen NMO150CK is a kit consisting of an NMO150C antenna and a NMOK mounting kit.
The NMO150C is a 5/8th's wave antenna, which does not have a coil in the whip. It has a 51" tall chrome whip. The "C" indicates the chrome.
The K indicates it comes with the NMO mount with 17' of RG-58 and a PL-259 connector. That connector won't fit your radio without a bunch of adapters that will put a lot of strain on the antenna jack on the radio. That usually leads to a fracture of the solder joint and a non-functioning radio.
The photo you are showing is an NMOU150d.
The NMOU150 is a loaded 1/4 wave, and Larsen still shows it at 18" tall. The coil in the whip is to make it look like a cellular antenna for undercover work. Not going to work any better than a regular 1/4 wave antenna.
