Low Speaker Volume on XPR-7550e
zsauve
Oak Creek, WI
Is there a way to turn up the speaker volume on the XPR-7550e? I have the radio's volume knob turned up all the way and my old CP-200 is still much louder than the 7550e. I looked in the CPS and couldn't find any obvious settings. Any help would be appreciated.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Go onto your audio settings and change Environment to Loud. This gives you lime an 8db boost. Also, if you want terrible RX audio, set your audio preference to Level 3. This only boosts high frequency audio components. Audio is distorted, but loud. TT
N1GTL
CT
Use the tuner software and increase the softspot setting for the audio level. Default is usually around 185-188. Bump it to around 215-220.
CanesFan95
Was Homeboys-Scanna
Banned
FL
The rated audio is only .5w which seems rather lackluster for a (supposedly) top-of-the-line radio.
romanr
Cheese country
The XTS5000 audio was/is rated at 500mW. It was the top dog until the APX series came along, and even the APX6000 has a 500mW audio spec. "More is always better", but 500mW can be pretty loud if the designers know what they're doing.
