carlsberg1664
I'm glad you were able to monitor{using theTRX-1} what I am trying to monitor with my scanner.
Is this the only frequency you're having an issue with? What other channels are you monitoring....I'd be interested if you can get Lawrence, Haverhill, Nashua, etc., which would rule out any antenna issue. Do you have the NEMLEC/BAPERN channels? If so, how do they do?
Lowell is using P-25 Conventional. Those are FM frequencies. The NAC xxx defines them as P-25 in the scanner. So when you program the Tone as NACxxx they will be read by the scanner and will show as P,-25 on your scanner display.
Not sure how you have it set up but make sure the scan sets are enabled for the scan lists in use.
Just to be sure, you have 482.4125 NAC366? Do you have it in P25 mode?
Lowell channel 2 is full time encryption, so you won't hear anything on that.
How do I check to see that it is in P25 mode ?
the NAC is what makes it scan for a digital signal... I would change the NAC code to search, because they might have changed the NAC code for access! It is a conventional frequency that is P25 that is what the NAC code is for!
FM has nothing to do with weather its digital or analog... if it is digital, then a NAC code is needed, if it is analog then a CTCSS is used!
I see your scanner says:
Lowell PD
FM 482.412500
NAC 366
And mine says:
Lowell PD2
Auto 482.412500
NAC 366
Looks like yours is set for FM mode and it should be in Auto mode. Did you program these manually or pull them from the library on the memory card? Do you have a recent database on the memory card?
prcguy
I would start over and download the whole Lowell system and see what comes in. You could always remove what you don't want later if all works well. I don't believe you need to change any settings. Just make sure the Scan Set for that Scan List is on.
