Lowndes County Not Picking Up Frequencies
kg4yxi
Valdosta,GA
I have a PSR-600 have been working fine and i know i'm not the only one in Lowndes County with this problem I'm trying to figure this out for 3 other people with PSR-500 & PSR-600 scanners. I can not get any Thing to work I use win500 software use RR to download although i downloaded the new list it only gives me (1) CC on my other saved file i have(8) CC i have used the rebanded trunking tables and i can not get anything, Does anyone know what else i can do or what im not doing right so we may resolve this issue for me and my friends. Thanks Alot....
wise871
N.W. Florida
Have you done a scan for a new control chanel? They may have changed it. Also do you have Trunking table set to Custom? When I look at the Trunking Table from the Web Import it looks fine.
kg4yxi
Valdosta,GA
Not Picking up Lowndes County
I Have Tried The New Control Channel It Now One Has One Were Before It Had 8 I Changed The Table To Custom Went Down And Changed To 800mhz(rebanded) Still Nothing. I Searched Channels Can Pick Up Off Of Search It Flashes P25 While There Talking So Im Not Sure What They Have Changed To When I Download Yes Everything Looks Fine But There Is Only 1 Control Channel And I Can NOt Pick Up Anything.
N8IAA
Fortunately, GA
Uncheck the Control Channel only box. It will import all frequencies. This is important if no one has used Pro96com to find all CC's. Including the alternate ones. If you press the MAN button on the scanner, then the TSYS button, then the ANALYZ button and scroll through the frequencies with the UP/DOWN buttons, you will find the active CC. Me, I'd use Pro96com and submit the changes to the GA database.
HTH,
Larry
bravocom25
Valdosta, GA
Thank you. I forgot to repost the next day stating that I did just that and it worked perfectly then. Now I'd like to figure out how to scan for frequencies/talk groups to find public safety groups in different cities as I'm traveling. Do you happen to know if this is possible with using the RR database?
