LPDA antenna problem
nikkv886
Hello!
I want to design an antenna that works good in four different frequences (930MHz, 1880MHz, 2150MHz and 2400MHz). I'm thinking about making a LPDA that has four elements, each adjusted for the different frequences.
My first question is if this is a good solution or is there a better way to design an antenna with these features?
If it's possible to design the antenna this way, what is the minimun
distance between the elements?
BR
Niklas
Al42
Long Island, NY, USA
What services are you designing for? I can't think of any particular kind of service that would be present on all bands. (And it's easier to get gain at the 3 higher frequencies with other designs.)
nikkv886
Thanks for answering, I'm building a high frequency power detector, that can cover all of the above mentioned bands. I want to keep down the size as much as possible.
Any ideas ???
IXNAY
Simi Valley
Lpda
It would be impractical to build an LPDA at S band. For the home builder, a biconal or discone might be broadband enough to cover those frequencies.
Typical L and S-band antennas are dish or corner reflector with a waveguide feed. A dipole feed can be used a L band, but the dimensions must be close. These are single band antennas.
For simple power detection, a reflector with a voltage probe feed and an LNA would work broadband. A microwave detector diode and voltage amp would give a relative DC value of the received signal.
