Lpe-200 Bin file
Does anyone have a .bin file for the lpe-200.. my radio wont even turn on as I get the black screen.
morganAL
Somerville, AL
I had the same thing happen to my LPE. Turned out to be reference oscillator (crystal) had died. I had to send it off and get it repaired. It also required a radio recovery. I hope you have saved a copy of your feature data.
rescue161
KE4FHH
Hubert, NC
Yes, he did save the feature enc, bin and tracking files, so he's good to go there. I tried to help him out, but nothing seemed to be working. Hopefully it won't be too expensive.
I tried to use the recovery option in the "radio Maintenance". It says.. loading bootloader. and then it says "No radio code detected in radio" select a radio type to continue. I select lpe-200 system... and then it asks me to select a .bin file.. there is only one option so I choose it... it says to restart the radio in programming mode...it loads the rambootloader.. and then the radio says "program erase" and then it says "program write".. it goes for awhile and the radio says "program status success"... the computer than says "could not find radio code after write. Try power cycle or radio and retry recovery. Radio flash may be damaged or flash voltage not present" after that however if I try to load the feature and tracking data it works.. any ideas? this leads me to believe that the .bin file that I have is not the correct one for my radio.. any ideas?
