LPE-200 - Model Change (Scan to System)
rescue161
KE4FHH
Hubert, NC
I just got a replacement front for my LPE-200. I had the 6 button front, but ordered the full keypad because the 6 button front was not available.
It still functions as a 6 button front and that doesn't bother me in the least, but I'd like to make it into a Systems model (full keypad).
I tried to change the type, but when I write to the radio, it stops and says that the model type does not match. Is there a way around this?
TDHG4U61
Hello, In the software there is a section where you have to change the radio type. Go to another part of the software called Radio Maint. Near the top tab click on LPE.
1) Read the tracking data file and chang your radio type to 96/99-HP System.
Reprogram updated tracking data file to your radio
2) Without re-setting your radio into program mode (leave radio as-is after programming
tracking file to radio), OPEN the scan personality file and change the radio type to
PRISM HP/LPE.
3) Go to Prism keypads option screen and select Prism keys (that is the system keypad)
If keypad information is missing, just press press the default keypad button on that
screen.
4) Reprogram the radio. Radio should act as a system model.
I have done this many times in the past but no longer own a LPE . If you have any questions drop me a line TDH19614U@YAHOO.COM
fdnybuff18
NY
Guys,
Does anyone have the part number for the System Front, I would like to make my scan LPE-200 into a System Radio. Thanks in advance.
fdnybuff18
WCRadioGuy
Salisbury, MD
fdnybuff18 said:
Guys,
fdnybuff18
The part number for the System Front Cover is SXK1073808/2.
fdnybuff18
NY
WCRadioGuy,
Does that part number include all items to do the switch over from Scan to System or is there another part number? THanks again.
fdnybuff18
rescue161
KE4FHH
Hubert, NC
That part number is correct. It includes the display & buttons. You may need a main gasket, but I did fine withthe original one. I also ordered new knobs for mine as the old ones were pretty worn.
I got the parts from Mutual Aid Supplies, Inc. They were the most reasonable on price.
www.mutualaidsupplies.com
Hope that helps.
fdnybuff18
NY
Scott,
Sent you a PM on this. What was the price on it. Another compnay just gave me a very expensive price.
FDNYBUFF18
