Lpe-200
Hey there,
I have a quick progammer question. I programed my radio with a personality file that a friend of mine is using with his LPE. The personality is working fine on his and all the previous ones that he has put on my radio has worked fine.
The problem that I am having is that when i move to some systems on the radio, it says "invalid sys" . It works fine on his radio for some reason and not mine.
Does anyone have any ideas on how to resolve this issue?
mitaux8030
Silent Key
Home
Sounds like your LPE doesn't have as many SYSGRP as your friends. You can still program or load well over the limit that is imposed, and the only error you get is the "invalid sys" you've seen.
The solution? Buy a new Feature Encryption String that will 'unlock' more SYSGRP for your radio. You won't be able to use the Feature String from your friends radio as each Feature Encryption String is uniquely calculated from your radios Electronic Serial Number.
bar422
I ran into the same thing recently with a P7100 and that's what the problem is.
