LPE200 Programming issue.
stuck22
British Columbia
Hey there guys, I just found an old LPE200 in a box of mine. I threw in a battery and I guess wherever I got it from had disabled the buttons. When I tried to "read" it with Programmer, I put the radio into programming mode, the hit "read". But everytime I tried that the radio freezes on "PROGRAM SELF TEST" and the software says cannot read the radio please make sure its in program mode.
Has anyone else seen or heard of this problem? All I want to do is Read the radio.
JungleJim
Sounds like you are using a ribless cable on a radio with old flash code. Radios with flash code P1R09B00 and earlier cannot be used with the ribless cables. You would need the macom rib with power supply.
To check the flash code version press the "M" menu button and use the up/down buttons to scroll through to the "revision" item. Press the "M" again to enter that item and scroll up until it says "FLASH VER" on top and your flash version will be on the middle line.
stuck22
British Columbia
Ah that would make sense. Unfortunatly the "m" button doesnt work on this radio. I guess whom ever programmed it disabled all the buttons. So I cant even see what kind of radio this is. All I know is KRD 103 104/A32 R2A
