Hi,
I am trying to run LLRP in fastlane 2.165. I have most everything else working:
Here is the contents of my LRRP config file:
192 695 ; first line must be map window origin
550 1000 ; second line must be map window height and width
15 292 ; third line must be font height
15 ; fourth line must be map zoom level (0-18)
2847380 1931599 ; fifth line must be encoded map center
. ; sixth line must be path to OSM map data files
.\USA.csv ; seventh line must be path to DSD+ LRRP data file
kilometers ; eighth line must be miles or kilometers
Infinite ; ninth line must be maximum data age
I know from the config file I am missing the OSM map data files. I googled and found a website but was unable to export the files as the web-page failed to generate it.
The system I am working with is in Winnipeg Canada 152F5.00A. Can you tell me where to get the files. Also what about line 5 of the config file how do I find that value out?
One other note/question. Should my VC Channel Activity window only show one line of voice grants? Because that is all I ever see even when there is more that one conversation at the same time. Do I just look at the CC Activity window?
Thanks, jets
Thanks, jets
