LTR and LTR SCAT
Mattsenft
Harrisburg, PA
LTR systems do not use audible control channels. All their data is subaudible. Therefore they don't sound any different than a conventional channel when searching. As far as I know there is no LTR SCAT. I believe you might be confused with EDACS SCAT.
N
N_Jay
Guest
LTR does not need SCAT, since LTR will trunk one channel without and changes or enhancements.
cg
Connecticut
LTR does not need base and offset, that is a motorola thing. LTR uses logical channel numbers (LCN) as does EDACS channels.
The PRO96 does not do LTR trunking.
chris
Curfew
Sorry about the mix up. How about id of a SCAT system? Would the conversation stay on one frequency and then disappear as a trunked system or would it be as a LTR where a regular radio transmission is heard? Thanks, John.
ocscan
Ottawa, On
EDACS SCAT systems sound like a standard EDACS control channel which then drops the control channel stream to carry the voice traffice, once voice traffic finishes the EDACS control channel TX resumes.
