LTR Multinet
thadude
Matagorda County,TX
any one know what type of Encryption/Digital Format's that LTR Multinet has or is capable of transmitting for voice privacy ??
D
DaveNF2G
Guest
Check Transcrypt's website for their marketing details. Any pass-through encryption (radio to radio with no processing enroute) should work.
thadude
Matagorda County,TX
K, i only ask because the County sheriffs office here has a back freq for 10-1 signal or sensitive pri 1 info, and when there is a transmission on this freq it is in some sort of digital format and i was wondering if there is anyway to figure out what exact type is in use as far as encryption or digital and if there was a way around thier privacy for this freq ~!~
D
DaveNF2G
Guest
It's probably a conventional channel if these transmissions always appear on the same frequency.
Obligatory warning: Attempting to decode an encrypted signal is a federal offense in the USA.
thadude
Matagorda County,TX
Yes thier frequency's are conventional and all of them are analog , but 2 Base/Mobile Freqs Broadcast with Digital over the analog , i appreciate the TransCrypt addy , helped alot , i think they are using VoSEC Digital Encryption on the particular frequency, and from what TransCrypt claims is that even the most determined wont Leak a transmission useing such protocol. so i guess its kinda screwed permanetly, thanx for the help though
