LTR observation and question about system programming
edweirdFL
Daytona Beach, FL
I've been monitoring a local LTR system used by a college and have been seeing something which is different than what I'm used to seeing on business systems. Normally users always have conversations on a common talk group, but not in this case.
This system doesn't have different companies using it, but does have different groups of folks who support a single organization. For this example lets use A, B, and C.
One talk group seems to be used by the base station(just a name, it's a repeater system, but this users coordinates all of the groups), and when they speak, all of the other groups hear it. They will call someone who's using a handheld. In this example lets say the call goes out on group A.
When the person on the handheld answers, more often than not they answer on a different talk group. Lets use B for this example.
The base hears then and a conversation ensues with each party using their own talkgroup for their parts. It goes back and forth on A and B in this example.
Later the Base will call a different user on A and they might answer on C.
Lastly, it does seem that when two users in a common group talk, the same group is used, for instance B. If they are having a conversation and the Base user wants to comment, the Base will show up again on group A.
I also have seen where a person in group C heard the Base (A) talking to group B but didn't hear the B replies.
The users have mentioned channels.
*** My assumption so far ***
These radios have scan lists programmed, and also have a home group for transmit programmed. The BASE scans all of the groups for RX and transmits on A by default.
The handheld users scan their home group (B or C) as well as group A which the base uses. When they transmit they use their home group (B or C)
The benefit to this setup is the Base can always get ahold of the hand helds, and they don't have to hear the conversations within the other groups of users.
The downside to this setup is the BASE hears all of the system traffic, and all of the users hear all of the BASE traffic.
It also seems that the users aren't trained to change to a different group if they want to contact a member outside their group. The Base has been relaying those comms, and they act like there's something wrong with the radios because they can't hear the other party whern the Base can.
Does this seem possible, and have you seen or heard of an LTR system being setup this way? Seems like they could have just let the groups stay on their own group and have the Base contact them on it. If they needed an All Call setup, then create a single group that they would scan, but train the Base user not to use it all of the time. Also train the users to switch to the other groups channels if they needed to talk to them.
Thanks,
Ed
pro92b
Mutated Member
It's not uncommon for each mobile unit to be on a separate talkgroup in LTR. Taxis and tow truck companies often do this to cut out idle chit-chat between mobile units.
BirkenVogt
BirkenVogt
Yes all it is really is a programming issue. The radio is not even really "scanning" it is just listening on one talkgroup and transmitting on another or if the talkgroups are all on the same home channel then it may listen for multiple talkgroups at the same time.
Birken
Joriga
you can also use the talk group for caller ID or unit ID. You program the radio for Block ID Decode. It is kind of slick actualy it is silent so there is no data squak for unit ID.I have a customer on my system set up that way only problem is if you don't allow for expansion you get to reprogram an entire fleet every time the want to add a radio ???? JD
edweirdFL
Daytona Beach, FL
I am also hearing data squalk on each transmission, so I don't think they did it for that reason.
I also have heard different non-base users on the same talk group, so I know it's not an individual talk group per radio setup.
It's a 3 channel system and all of the groups I've found so far are 0-01-01x
Thanks again for everyone's comments.
Ed
slicerwizard
Toronto, Ontario
Most LTR radios can be programmed to transmit on one group ID (e.g. 01-001), but receive a range of ID's (e.g. 01-001 through 01-250). This can be used to give every radio its own "ID" and a lost/stolen radio can be blocked by the system.
It's a hack to get around the lack of radio ID's on LTR systems.
Skud
Middleville, MI-Barry County(Near G.R. & Ionia
for programming LTR on my Pro-96, do i mark the channels and bank at MOT or something else?
I am testing Walker here in Michigan
System Type: LTR Passport
System Voice: Analog
Last Updated: Updated General System Info
Hits: 799
System Frequencies
Site Description
001 Primary 01 857.26250 02 857.43750 03 860.43750
edweirdFL
Daytona Beach, FL
The Pro96 doesn't trunk LTR of any kind, so you'd have to enter them into a bank as conventional freqs, and not be able to follow a specific talk ID.
Of the scanners that do track LTR, I don't think any will follow the Passport systems. There is a software solution. See the LTR info in the Wiki here.
Ed
