OK, we are getting there. I suspect you are talking about Warner Communications? I notice that most of the LCNs listed for those systems are not confirmed and are listed as 1,2,3,4,5,etc. Seldom do LTR systems follow an order like that, rather they use an offset rule, or skip LCNs. For instance LCN#1, 3, 5, 7, 9 and the even numbers will be skipped. The first thing you should do is confirm the proper LCN position for each frequency. You can do that by simply entering in the frequency and watch what pops up. The 2055 displays the talkgroup and over on the right side of the screen the actual home channel will appear, i.e.: R03. Occasionally, a talkgroup will appear on an overflow channel if that particular talkgroup's home channel is tied up. You may see 0-03-095 appear on LCN#1 in the system. The R01 will tell you that that frequency is in fact LCN#1 and not #3. Once you figure out the proper LCN positions for each frequency you can enter them in the correct channel number as LTR system and monitor the system. Beware however, companies who set up LTR systems like to mix and match frequencies and figuring out which frequencies go with which systems can sometimes be very frustrating process. Good luck.
