LTRTrunk - Configuring Window Size, Windows XP
KD4YGG
When I launch LTRTrunk, it opens full size on my screen from the Command Prompt window. I'd like to keep it to a manageable window size so I can see other things on the desktop.
I'd like to get some screenshots of the program running, especially when collecting data on Multinet and Passport, but the full size prevents grabbing the image - all I get is text.
TRUNKER and ETRUNK do not do this, but LTRTrunk does.
I've tried doing the old F12 button to resize the window, but apparently I'm doing something incorrect.
Anyone out there with a solution?
loumaag
Silent Key - Aug 2014
Katy, TX
Chris, with the understanding that I don't have a XP box to my name, try <ALT>+<ENTER> to see if the full size screen will switch to a window. If it does, then you can do "window" things with it. :)
KD4YGG
Re: LTRTrunk Window Size
Lou
Thanks for the shortcut.
I finally figured out I could do this by alt-tab and then clicking on the minimized window, and change the properties from Full Screen to Window.
Just curious if I can code the LTRtrunk.bat file with some command to do this automatically.
loumaag
Katy, TX
Well the shortcut that you specify for calling the .bat file should allow you to specifiy how the window is to open. However, it has been reported that this affects different implementations of the various "trunker" programs differently. I am beginning to think it may be a function of what compiler was used on the program.
