Lubrizol Trunked system(s) - Wickliffe and Painesville (Lake Co)
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Hi Folks,
The Lubrizol Corporation has had trunked systems in Lake Co (Wickliffe and Painesville) for years. They were rebanded in 2009/2010 (but the database still reflects the old frequencies).
Then in 2011, the license was changed to reflect only DMR emissions.
Here are the current Lubrizol sites in the DB. I am confident that you cannot monitor either of these with the information in the DB. I am confident that if they are online, they are using different frequencies and are now DMR. They are probably either two networked Motorola Capacity Plus sites or two Motorola Connect Plus sites.
Current DB:
Lubrizol Wickliffe: https://www.radioreference.com/apps/db/?sid=1826
Lubrizol Painesville: https://www.radioreference.com/apps/db/?sid=1827
If you are within earshot of these systems, please use DSDPlus (or program your scanner with a new DMR Trunked system for each site) and monitor these and let us know the details of the sites now. We'd need to know if they are Capacity Plus or Connect Plus, and we would need to know the control channels. You could run LCN Finder on a BCD436/536HP or a SDS100 to determine the LCNs if you program the system/sites in your favorite list as a DMR trunked systems with the appropriate frequencies per site.
https://www.radioreference.com/apps/db/?fccCallsign=WPAD790
Wickliffe
860.9625
861.4375
861.7375
861.9875
862.7125
Painesville
861.2125
861.6375
862.1375
862.4625
Please submit any updates to the EXISTING database entries in the DB via the submit button. If the systems have indeed changed to DMR as I suspect, then once proper information is submitted for each site we will create a new DMR trunked System / Sites in the DB and deprecate the old.
We really appreciate the cooperation of anyone who can help out.
mtindor
OH/WV DB Admin
Is there really nobody in Lake Co that can check into these systems? I'm thinking there is. If you are in Lake Co and can snoop out these systems and just need some guidance, at least make a post and let us know you are there and willing to help out.
Mike
