im going to put it into my unication now and see if I can get anything!
Unfortunately I cant get reception to the system unless I go outside on my porch which faces south into Luzerne, and I didnt get out in time to get it I guess,Hope you caught it quick. Seems like it’s stopped again.
Well this is twice I’ve heard it happen during the afternoon now. I’ll keep an ear open for it again the rest of the week.Unfortunately I cant get reception to the system unless I go outside on my porch which faces south into Luzerne, and I didnt get out in time to get it I guess,
Luzerne was dispatching on TG 1025 today around 3:06
The patch could only be turned on and off from a dispatch console not a field subscriber unit.Perhaps the tg is not strapped, and only comes up when a special someone decides to turn their subscriber onto the channel.
Not really what I'm saying.The patch could only be turned on and off from a dispatch console not a field subscriber unit.
For those of you that are using eiother the Uniden SDS100 or SDS200 are you porogaminng this system in as conventional frequencies? I used Proscan to downlod the system from the RR database, and for whatever reason it won't scan any of the frequencies as programmed from the database. I have boht the Uniden 436 & 536 scanners as well but havent tried downloading the system fromt he databse into them set to see if it works on them.
After you imported from the RRDB, did you write the Favorites to the scanner?For those of you that are using eiother the Uniden SDS100 or SDS200 are you porogaminng this system in as conventional frequencies? I used Proscan to downlod the system from the RR database, and for whatever reason it won't scan any of the frequencies as programmed from the database. I have boht the Uniden 436 & 536 scanners as well but havent tried downloading the system fromt he databse into them set to see if it works on them.
Countywide (All) |
PD Zone A |
PD Zone B |
PD Zone C |
PD Zone D |
PD Tac 1 |
PD Tac 2 |
PD Tac 3 |
PD Tac 4 |
PD Tac 5 |
PD Tac 6 |
PD Tac 7? |
PD Tac 8? |
PD Tac 9? |
PD Tac 10? |
PD Tac 11? |
PD Tac 12? |
WBPD Dispatch |
WBPD Ops 1? |
WBPD Ops 2? |
Sheriff Dispatch |
Sheriff Ops? |
Prison 1 |
Prison 2 |
Prison 3 |
PD Countywide 1? |
PD Countywide 2? |
EMA |
Schools North |
Schools South |
Schools 3? |
Schools 4? |
Schools 5? |
Fire East |
Fire North |
Fire South |
Fire West |
FD Ops 1 |
FD Ops 2 |
FD Ops 3 |
FD Ops 4 |
FD Ops 5 |
FD Ops 6 |
FD Ops 7 |
FD Ops 8 |
FD Ops 9? |
FD Ops 10? |
FD Ops 11? |
FD Ops 12? |
County Fire |
County Fire 2? |
County Fire 3? |
WBFD Dispatch |
WBFD Ops 1? |
WBFD Ops 2? |
EMS Response |
EMS Ops? |
MED 1 |
MED 2 |
Hosp GWV |
Hosp GSB |
Hosp WBGH |
Hosp LVH |
Hosp VA |
I was able to figure out why they werent being scanned, it was the delay setting. I have one 436 scanning the North Simulcast frequencies, and another one scanning the South Simulcast frequencies, recording both radios 24X7 using Proscan. I'm located up on a hill in Shavertown with the antennas about 60 feet up in my attic as I can have external antennas.I haven’t messed with the system much in my 536 yet but it works fine as a P25 system in my 436, 100, and 200 when there’s activity on the system which is only occasional right now.
Unfortunately I can’t help much with the Proscan. I hand program all of my scanners and use Sentinel only as a backup to save the programming to in case the SD card crap out.
Is it possible the talkgroup identified as fire dispatch is one of the four main fire talkgroups below (North, South, East, West) and that's why there are not transmissions all the time? Or, it could be that county fire talkgroup and they are still fiddling with things leading to the inconsistent transmissions.
