rinkerk
- Joined
- May 10, 2005
- Messages
- 41
- Reaction score
- 0
Hello all.
I have a mostly "homebrew" 70' longwire end fed with a 9:1 WinRadio longwire "transformer" ( multiband Balun)
Been using this on several receivers for some time now. It really works well using RG6 coax ( 50' to the shack.) This is a receive only antenna.
Impediance matching using an MFJ-959C Tuner Preamp.
Dont need the tuner or the preamp with the Icom R75 but it does improve reception on the Grundig Sat-800.
I just got in another WinRadio logwire matcher and plan to set up a 300+ lenght longwire running the opposite direction of the 70' sloping longwire I'm using now.
These longwires are approx. 40 ft AGL at my QTH, Using a 20' mast mounted on a tripod on the roof.
I plan to use the 300' longwire for the LF band. This one will be almost horizontal, using a PVC mast about 20' at the end. ( so it will slope just a little)
Anyone use the WinRadio longwire balun? I expect after the ground system I'm installing at my QTH, it will be a better match for LF beacon Dx MW, and the lower HF bands.
Any input for you all experimenting with HF antenna configs would be much appreciated.
I also monitor the VHF UHF band using a Scantenna, and plan on putting up another VHF antenna. I think I want to either build or just buy a discone for the scanners.
It's driving the YL a little crazy righ now, but we have enough space in the back yard to do this.
(She'll get over it soon)
Regards,
Kevin
Regards,
Kevin
