M/a-com Radio Feature List
GILMOORE
Just to let everyone know that Ron and everyone else that helped out with the lpe-200 radio that the support was wonderful and the good news about the radio is that I don't need that file Ron has been looking for.
rmiles
Yes, I do! :D I think he's confusing voice and feature encryption again. To all those experts out there, I STILL need to get in contact with someone at TAC to get the feature string for this radio.
rescue161
KE4FHH
Hubert, NC
Okay. He still needs the file because that file is going to tell your LPE-200 what it is allowed to do. If you don't have that file, then you won't be able to do any of the following:
M/A-Com Wireless Radio Feature List
01 - Conventional Priority Scan
02 - 3 site scan enabled
03 - Public address allowed
04 - Group scan
05 - Priority system scan
06 - Wide area system scan
07 - Dynamic regroup
08 - EDACS emergency operation
09 - T99
10 - Conventional emergency operation
11 - RX freq preamp select
12 - AEGIS/VG TX and RX operation
13 - VGE encrypted calls
14 - DES encrypted calls
15 - VGS encrypted calls
16 - Data TX and RX calls
17 - Status/Message TX calls
18 - Test Unit operation
19 - M-RK I Second Bank operation
20 - System Model Keypad operation (MDX)
21 - EDACS Security Key
22 - Profile Operation
23 - Narrow Band Operation
24 - Auto power Operation
25 - Over-the-air channel set expansion
26 - Duplex Interconnect operation (IPE only)
27 - ProSound Junior (IPE only)
28 - Multi-Radio ProSound (MuRPS)
29 - IMBE vocoder operation (EDACS ProVoice)
30 - (not used)
31 - Battery ID feature
32 - FIPS-140 DSP and CRC checking
33 - P25 CAI support (APCO-25 Conventional Only)
34 - Direct frequency entry on system models
35 - (not used)
36 - Radio to radio personality cloning
Those are the FEATURES that the feature encryption file will enable depending on the actual file. The reason that it's encrypted is because M/A-Com doesn't want everybody and their mama upgrading their radios for free. Say you want to add Pro-Voice to a non-Pro-Voice LPE-200. You call M/A-Com and ask for Option 29. They ask you what your serial number, ESN and current options are and then they make a new Feature Encryption file and email it to you. You enter the new string of numbers into the radio via Radio Maintenance and viola, your radio will be able to listen to Pro-Voice.
The reason that your radio is not working is because you went into Radio Maintenance and edited that Feature Encryption string. Now your LPE-200 doesn't know what to do, because the feature string is wrong. You probably thought that it had something to do with voice encryption. It has NOTHING to do with voice encryption. Voice encryption keys are not stored on the radio. You have to have a key loader/key fill device and a cable to attach it to your LPE-200. The key is stored in the KVL and "loaded" from the KVL to the radio. Once this happens, the radio will TX/RX encryption(DES, AEGIS, etc). You have to have the right key and the right version of encryption (DES, AEGIS, etc) though or the radios won't be able to talk to each other.
rmiles
Just to clarify, AEGIS is not an encryption algorithm. It's a digital voice codec, like ProVoice, VSLEP, or P25. However, AEGIS or ProVoice is required to run encryption on M/A-Com radios since their radios will not encrypt analog voice transmissions, unlike Motorola radio which will encrypt analog voice. M/A-Com radios only apply encryption to digital voice transmissions.
rescue161
KE4FHH
Hubert, NC
Gotcha. I must have still been asleep this morning... lol
