M-RK Radios
jma91085
Our scout troop had two M-RK II Ericsson radios donated to us a long while ago. We have never used them but know we have a real use for them. Programming equipment and software was also donated. We have tried to program the radios but can't for some reason We need to program them to a frequency that the large camp we are going to uses. We have everything set right but when it is in the programming stage it gives a write error and says the Feature Data String must be even, but after checking it in the software it is even. Can anyone help......
bigbob19722000
MRK II
you need to check to see if the feature data i(encry. code) in the radio using the maintence file and if not re-enter that information using the maintence file.
once thats done you should be able to enter any freq you desire...however if that information was clear by accident then you would need to call MA/Com to get the feature encry code to re-enter it. If not you have two paper weights....
let me if that help
lou
