M120 PA swap Question
kayn1n32008
ØÆSØ
Sector 001
I have a M33GMC20A2AA, that is going to be used as a APRS Digipeater. Right now it is not very happy working at 144.3900Mhz even after tuning the PA. Is it possible to just swap a PA from a low split PA? or would it just be better to look for a M33GMC20A1AA radio and sell/junk the hi split radio? After tuning the PA, at 146.000Mhz it puts out 25w but at 144.3900Mhz it is putting out less than 15w with the same current draw. Is it possible to retune the radio to be happy Transmitting 25w at 144.3900Mhz? After making a cable to interface with an OT3m i found it had a flaky 16pin connector, upon examining it i found some 'tech' had pooched to connector trying to jumper the speaker pins on the underside of the board. needless to say, the connector was removed and a pigtail for the Audio out/in, PTT, COR, and Ground to a DB-9 was installed to fix the hack job.
