M1225 won't accept modified codeplug???
john98225
Bothell, WA USA
Not sure what I doing wrong ... I have a 20-channel VHF M1225 and a ribless RG-45-to-serial9 cable. When I hook it all up, the software 'reads' the radio fine and creates a codeplug. I saved it, then copied & renamed it, modified that file by replacing some frequencies, etc., and then tried to program the radio with the new file. Then it shows the message shown below. I even went back and tried it again with a new file that only condensed the alpha tags. Still wouldn't work.
Interestingly, if I hit the program icon using the original file, it works fine! Shows it's programming below with a time-graph, and then indicates it was successful.
I tried renaming the modified file with the "read" file's name ... wouldn't work - same error message.
Anyone know what is going on? Thanks in advance for any help coming my way.
John in Bellingham, WA
john98225
Bothell, WA USA
Figured it out!
Okay, turns out with my setup, at least, you evidently can't simply use Windows to "copy" a codeplug-file on your desktop, modify it & then try to program the radio with it.
But - as most of you Motorola-programmers probably know, I'm sure - I found you CAN have the software read the radio, save the file with a new name (like 'test1), modify the settings to your heart's content, and then program the radio with the new file! (I love it when a plan comes together!)
