M1225 wont turn on
Vaughn
I have an M1225, 20 channel UHF. This mobile was used as a base radio on a power supply for approximately 3 years. It suddenly stopped working for no known reason. I was told that someone had attempted to hook an external speaker in the accessory port and caused the problem. I did take a look at the pico fuse inside, but it looks normal. I'm assuming that if the fuse was blown, it would be visually evident, right? The radio wont do anything at all when plugged in, and multiple sources have been tried.
C138NC
Tactical Taco Consumer
NC Taco Command
well since you said someone was trying to hook up an external speaker into the accessory port, that probably COULD... not 100% sure, cause a shortage in the circuitry.
When you say multiple sources, have you tried getting it checked out by a Tech?
fineshot1
NJ USA (Republic of NJ)
Pico fuses do not have a visual indicator when blown. You must test them "out of circuit"
with a continuity tester such as a multimeter or DVM.
Vaughn
Negative, it hasn't been tested by a tech......only multiple sources of power. I didn't know if the pico fuse would be visually blown or not. If it is indeed the pico fuse, how much am I looking at having it fixed? I seen someone on here in another thread say they would fix it for $10, I thought.
C138NC
NC Taco Command
Shops usually charge by the labor fee and who knows how much replacements could be, I needed a volume pod for one of my radios, they charge 20 for the labor and 60 for the replacement. Could be cheap at different shops but 10 dollars isnt so bad.
