m7100 hardware error
durango5550
Booger D.
Hello all ,
after an extensive search for the answer , I can not find anything. Anyway my 7100 is showing a hardware error of 0004 , when that pops up it reboots and never does it again. Any help would be appreciated
Dan
Mattsenft
Harrisburg, PA
It's a flash checksum test error. You might be able to resolve it by reflashing the radio with code and dsp.
durango5550
Booger D.
I'm a little new to this Harris stuff :) could you direct me to reading material on this procedure ?
Mattsenft
Harrisburg, PA
Do you have RPM and a programming cable? Once you have those items it's fairly simple. Anytime you program the radio, the software prompts you to load code and dsp if you so wish. At that point it's just a matter of selecting the files you want to load.
durango5550
Booger D.
yes sir, have the stuff to program with. The files on the other hand are a different question , unless I'm missing something in the programming
Mattsenft
Harrisburg, PA
Radio code and dsp files were not included with RPM. They were generally obtained from Harris as needed to resolve problems or add features. There were some groups dedicated to the Orion and M7100 products. I would do some searching and you'll probably find them. Just an FYI though, the last time I checked you have to load both at the same time, so you'll need to get at least one of each type of file.
