M7100 programming
k4jbr
Woodbury
I just got a pile of radios and R18 . I made a db37 to 9db off Youtube video. Everybody wish me luck . I dont have a programming manual. I hope to put them on 2 meters. I am a general ham and hope to use them mobile for the higher power.
K2NEC
5F6
What was the point of this thread?
k4jbr
Woodbury
I was kinda hoping for a positive reply with help if I needed it. But got this. I dont know yet what to ask. Thanks
BMDaug
I am licensed…
Central Colorado, USA
If you have RPM you have the programming manual. The help section isn’t perfect, but it’s fairly comprehensive and it’s how I learned to program my little set of Harris radios!
Good luck,
B
k4jbr
Woodbury
I only have R18 I did not see a manual in there. Is the manual on the web for download ? I got most of my info off Youtube. We just got the radios
rescue161
KE4FHH
Hubert, NC
M7100 may have been programmed with RPM. If so, they can be reverted to use R18, but I wouldn't do that and would look for RPM as it is very easy to mess up the tuning partitions when reverting.
TDR-94
The HELP section in ProGrammer R18 is essentially the manual.The same is true for RPM.. It basically gives you all the information you need. If you can't figure it out from the HELP section, it's probably best to leave the programming to someone else.
Youtube "info" on these types of radios is comical at best, and is usually made by clueless ass clowns.
