M7100ip Programming
Ashtonsdadda
Oregon
I recently picked up a m7100ip and I've come to the conclusion unlike my older ma-com/Orion radios there is no way to convert this back to being able to be programmed with programmer 7 or 8. I've been told basically you need RPM to program it or back date it.
Is there a place or a private party who I can contact about having it converted back to being able to be programmed with programmer? I'm not willing to spend 2k for software for 1 radio. I've been reading a lot and it seems kb4cvn seems to have experience with these?
I tried over on the Yahoo groups. But I'll be honest there forum set up "groups" is a horrible design and lay out and I hate trying to operate around it. Thank you in advance to the help guys!
2wayfreq
Arizona
That is ONLY, if the feature bytes are not viewable from the menu so you can re-load them. The file provided in the blog will enable progammer to downgrade it. Any other Flash Levels, DSPs are easily obtainable on the net.
That process still requires RPM.
