M7300 Fixed audio output
N2PDQ
I have a m7300 and would like to tie it into a logging recorder. Does anyone know what pins on the rear accessory 44 pin connector I would need to tie into.
Preferably outputs that are fixed level outputs.
Dirk
DisasterGuy
Maryland Shore
Are you just looking to log a TG or is this a control station used for dispatch where you need to log the TX from the unit as well?
bobsmr
See the attached file.
  • M7300 Acc Connector.pdf
N2PDQ
The radio is just going to sit in a back room, and just need a fixed level of receive audio.
Dirk
N2PDQ
Pin 1 and 14 will give you the audio. You can set min and max volume in RPM2 to make the level fixed.
Thank you, But wont that also affect the speaker output, with the volume control, or is pin 14 separate from the speaker level. If possible, I would like to have an external speaker connected as a monitor, and for troubleshooting.
Forts
Ontario, Canada
Use Pin 5 (buffered discriminator audio out)... that's what I'm using on mine. Make sure to read the comments regarding this output in the file attached above my bobsmr.
N2PDQ
Unfortunately discriminator audio wouldn't work. I should have mentioned that this is a P25 system, and need the decoded audio.
How about pin 13 ALO audio?
