M7300 interfacing with Industronic PAGA system
tony1986
Hi guys,
I've been looking for a solution which will connect Harris M7300 desktop station to an Industronic PAGA system. Does anynoe have related experience? any help is welcomed!!
LMR_Dude
I've connected a M7300 mobile to a David Clark setup in a fire engine, so I know some things. I've never heard of PA/GA until I looked it up!
What do you want the radio to do?
tony1986
thanks for reply~we need to broadcast information through PAGA system via a radio, do you have any ideas?
LMR_Dude
Heres the pins you need:
1 EXTALO (Gnd)/ 13 ALO for the radios RX
In a front-mount radio installation, this 600-ohm ACcoupled
differential audio output from the mounted
(local) control head provides public address (PA) mic
audio from the head to a siren/PA system. In a
remote-mount radio installation, these two pins of the
radio’s DB-44 connector are not functional.
27 MIC HI (Tx audio)/6 EXTALO (Gnd)
External/Auxiliary Mic Audio Input. Fixed-level audio
input (i.e., input gain is not adjustable). Approximately
120 mV rms gives full-rated deviation. Use P4 pin 17
for ground(Pin 6)
18 INP1 (ptt)
7 GND
The radio must be programmed to recognize INP1 as a PTT source to get this setup working fully.
