Ma/Com M7100 IP No TX after programming
TonySoprano
All:
I have run into an adventure in reprogramming an M7100 for a sheriff's deputy. I am very new to this line, in fact it is my very first one.
What has happened is, I read the radio, changed some AUX I/O and channel personality functions, reprogrammed the radio, only to find that it will not TX RF power. It will TX signal, very weak but it is there. Like it's only running on the exciter. I created a blank personality file and programmed it back in, problem persists. I spoke to someone at Harris tech support, and they sent me new DSP and firmware files, I successfully uploaded them and re-loaded the radio's identity files, with no change. I can verify that the radio worked fine before the programming changes.
Here are the specifics:
Ma/Com M7100 IP 100 watt chassis, single control head.
WinXP Pro, using Conventional ProGrammer.
Cable: CA101287V1 into the high density 15-pin control head cable dongle.
Pers version: 34
DSP: F4R06C05
Flash: V2R09A05
I am completely stuck-any suggestions are welcome.
Thanks!
